Farmall F20 FINALLY enroute Nebraska to Illinois
doug in illinoi
03-20-2008 19:50:58
I have been wanting to get my grandpa's F20 here from the farm back in Nebraska for several years. Every time I thought was going to happen, something else needed done, one time I did have the trailer empty back there, but it was still frozen to the ground and ended up only bringing back my 49 Willys Jeep instead of both at the same time. Have a hauler needed a return trip load, was going to have him bring 51 Chevy pickup, 53 Cadillac, and 51 Ford Tudor on his trailer. Caddy has 4 flat tires, 1066 IH moved it about 5 ft. Ford has a locked wheel bearing. Pickup moved easy, so to at least use some more of the trailer they (one of my friends back there and him) did figure out a way to load the F20 on a two rail trailer. Now, what is the first thing I need to do as regards getting it running again? Have always kept motor free, pretty sure carb will need a good cleaning. Magneto? How do I see if needs rebuilt without pulling it off and end up with possible timing issues? I am planning on changing all fluids before moving more than a few feet towed or under it's own power. Thanks, DOUG
spencer13cat
03-21-2008 20:58:10
 Re: Farmall F20 FINALLY enroute Nebraska to Illinois in reply to doug in illinois, 03-20-2008 19:50:58
Always put fresh go-go juice in the gas tank. And have a spare set or two of fresh spark plugs and some starting fluid. I'm in St Louis, I'll be listening for the pops.
F-Dean
03-21-2008 18:10:07
I suggest that you rebuild the mag. That will produce a hot spark and make it easier to get running.
Buy a new coil, condensor & points from YT (this site) and install them. This should produce a spark that wiil jump 1/2 inch. You can test your mag before and after rebuilding it by cutting a 3/8 inch socket extension in half and put it in a drill. Find a 3/8 inch drive socket to fit the nut on the drive end of the mag and use the drill/extension to spinn the mag.
When you take the mag off, note where the distributor is pointing(1 o'clock, 9 o'clock etc.) and do not turn the engine before you re-install the mag.
While you are at it, drill a small hole in the back of the mag housing and connect a grounding wire to the condensor. Then connect this wire to a one-wire on/off switch from a H or M. This will make it easier to kill the engine.
PS: I live east of Springfield, IL
LenNH
03-21-2008 07:42:15
The mag should give a spark off a plug wire held near the block (give it a little space to jump).
Some very minor things can result in no spark:
1) dirty points (use a file, but NOT emery--it can short out the points, as I remember from the days long-ago when there were points in everything) 2) points too close together--not opening enough because the rubbing block has worn down. More important: 1) bad condenser (I think that can be checked with a continuity tester--unhook the wire and touch the continuity tester to the wire AND the body of the condenser; if you get a continuity reading, the condenser is shorted).
I HAVEN'T WORKED ON THIS SORT OF THING FOR YEARS, SO IF I'M WRONG, SOMEBODY PLEASE WRITE IN AND CORRECT ME. Politely, of course. 2) Weak magnet. I don't know if there is a good test for this on the magneto. If you pull off the magnet and it still attracts iron, it's probably all right. JUST BE SURE YOU DON'T CHANGE THE POLARITY OF THE MAGNET--MARK THE OUTSIDE AND PUT IT BACK THE SAME WAY. Charging magnets requires
a "magnet charger," which I think is something that you can make if you have to, but you'll have to find out how. Somewhere, someplace, who knows where, I probably have something in an old book on how to do that. If that is of interest,
drop me a line by e-mail and I promise to go into my lonely basement and look through some of the old repair books. Mags are just generators with points and a distributor attached, and have pretty much the same problems as generators and distributors. There is another unlikely problem with a mag, and that is a shorted armature. But...if you get a spark straight off, or after cleaning and adjusting the points (.013" with rubbing block on high point of cam) and checking condenser, you're probably in business. The impulse coupling has to work right. Magnetos don't put out much juice at cranking speeds, and the impulse gives the armature a spin to raise the voltage. The impulse pawl could be dry (there is an oil cup on the F-4), and of course it can be worn enough that it doesn't engage. You can hear it drop into the notch with a little clinking noise. If it doesn't drop, DON'T crank with the magneto
on. The impulse holds the mag until the piston is over top dead-center, but without the impulse being engaged, the engine will fire before top dead center and you'll get 55 cubic inches kicking back and trying to break your arm or your thumb (the entire engine has 221 cubic inches). I hope some of this is helpful. There is always the possibility that you've done all this stuff a dozen times and could write a book for those of us who haven't done any of these things for ages. I had two F-20s between 1980 and 1995, but they've both gone off to people who have the space to keep them and the time to maintain them.
doug in illinois
03-21-2008 15:31:22
 Re: Farmall F20 FINALLY enroute Nebraska to Illinois in reply to LenNH, 03-21-2008 07:42:15
It made it here safe and sound. Carb will need soaked, the choke is rusted open. Regards the Magneto, it does click-click-click as I crank the engine over. DOUG
F-Dean
03-21-2008 04:19:40
Take the carb off the F-20 before you haul it. The constant bouncing on the highway can damage the floats and cause problems. Based on experience of hauling F-20s from Nebraska to Illinois.
Ron in Nebr
03-20-2008 23:06:56
Is by chance the '53 Caddy still in Nebraska? Any chance you'd want to let it go? If so, where in Nebr is it? Used to have a 54 when I was a kid and would love to find another in decent shape around that same year.....it sure as heck wouldn't ever go to the scrap man!
doug in illinois
03-21-2008 15:25:22
 Re: Farmall F20 FINALLY enroute Nebraska to Illinois in reply to Ron in Nebr, 03-20-2008 23:06:56
The 53 Caddy is in south central Nebraska, not too far from Hebron. Sell it? Would have to check with my sister, it has been in our family on my mom's side since the day it was new. That would be her decision. Go ahead and email me back if you want to, we can discuss it. DOUG
ShaggyM
03-20-2008 22:26:45
Where are you located in ILL? Shaggy
doug in illinois
03-21-2008 15:27:56
 Re: Farmall F20 FINALLY enroute Nebraska to Illinois in reply to ShaggyM, 03-20-2008 22:26:45
West central Il, near US hwy 136, about 30 miles east of the mighty Mississippi.
