43h and 3 point
jay dee
03-21-2008 06:46:47
hi bought a saginaw (very happy) did the basic plumbing to the belly pump and it works fine
but the down force with a blade is really slow,
makes for a chilly day doing snow,added weight to it have 10-30 oil and drilled a pin hole in cap to breath.is there any more i can do or is that the way the old girl is going to be? thanks
CNKS
03-21-2008 17:43:47
 Re: 43h and 3 point in reply to jay dee, 03-21-2008 06:46:47
If you don't have 2 way hyd, the down port on the cylinder needs a vent on it. Saginaw usually sells them that way. Something as heavy as a blade should drop like a rock.
Hoss357
03-21-2008 08:50:07
I put a saginaw 3pt on my 400 I don't have down pressure? The cylinders are 2 way but my hydralics aren't.
Steven f/AZ
03-21-2008 09:23:42
 Re: 43h and 3 point in reply to Hoss357, 03-21-2008 08:50:07
Hoss357 said: (quoted from post at 08:50:07 03/21/08) I put a saginaw 3pt on my 400 I don't have down pressure? The cylinders are 2 way but my hydralics aren't.
400 hydraulics can be set to be one-way or two-way. Procedure is in the manual.
Allan In NE
03-21-2008 07:23:36
Yep,
Sounds like you're using one-way hydraulics with those two-way cylinders. You're fighting against compressed air on the "down" side.
Allan
Steven f/AZ
03-21-2008 07:16:21
Get a spool valve and set it up for two-way hydraulics.
