H water pump rebuild question
neblinc
03-21-2008 06:54:00
I have all the bearings & seals installed, just need to put down the felt washer and this darn $5 piece of packing. I can find no mention of how to put this piece on. Do I put the shaft in first then wrap the packing, or put in the packing first? does it overlap or go on in a spiral?
Randy
third party image[url][/url]
neblinc
03-21-2008 17:52:58
 Re: H water pump rebuild question in reply to neblinc, 03-21-2008 06:54:00
Sheesh, I got that little bitty piece in the package for 5 bucks :cry:
Guess I will make a trip to NAPA and see what they have.
Thanks everyone!
Randy
Kevin Meier
03-21-2008 13:39:31
I usually use the one piece rope packing to rebuild. About 18 inches long. Cut it into sections long enough to wrap around the shaft 1 revolution or more and pack it in using the nut a section at a time with the shaft installed.
neblinc
03-21-2008 12:03:50
It only shows using one in the parts list, where do you see I need 3?
Randy
CNKS
03-21-2008 17:50:01
 Re: H water pump rebuild question in reply to neblinc, 03-21-2008 12:03:50
The listing for the diagram has an "x" in the number required column, that means as many as it takes, I would not use less than 3. It may still drip, my SH did so I then used a rope from NAPA as in the other post. It leaked too, but eventually stopped. I was told to put locktight on the packing nut threads, as the nut can work loose.
riverbend
03-21-2008 17:47:03
I'm not sure where I got the number 3. In my parts book it says 'as required'. The illustration shows three and that's what I got when I rebuilt my water pump. I do no recall if that is what the partsman said or what.
Greg
riverbend
03-21-2008 17:49:08
 ps. in reply to riverbend, 03-21-2008 17:47:03
It has never leaked since, so three has certainly been adequate.
riverbend
03-21-2008 11:19:10
Remove the packing nut. Put the shaft in. Wrap the packing around the shaft. I think it takes 3 pieces. Then the nut. The felt washer goes between the housing and teh pulley. I&T has a cut away drawing that shows it (#17) and the packing (#19), page 46 fig. IH400. IH Service Manual has the same drawing (page 23), but the I&T is better.
GReg
