torque to spin crank with new bearings question
riverbend
03-21-2008 11:33:06
I'm putting new bearings in my Super C. When I try to turn the crank, it seems really tight at first and then get easy once it starts to move. It takes 30-35 foot pounds of torque to get the crank to start to turn and then it drops to around 10 ft.lb. or less.
Anybody know if this is typical ?
Anybody know how much torque it should take to turn the crank when the rods, pistons and rings are installed ?
Thanks
Greg
El Toro
03-21-2008 14:33:14
 Re: torque to spin crank with new bearings question in reply to riverbend, 03-21-2008 11:33:06
If you had your local machine shop to measure your crankshaft and they furnished all the bearings you're probably good to go. Squirt some more engine oil into the cylinders and crank her over with the starter until you see oil pressure on the gauge & then start her up. Hal
Roger46
03-21-2008 14:23:15
Did you check the bearing clearances when you put it together. I always use Plastigage to make sure I have the correct running clearance. It is a little more effort; because you have to torque the bearings down an extra time with the Plastigage in between. Have you ever used Plastigage? You can buy at any auto parts store. Roger
ihc49er#2
03-21-2008 12:57:17
feels good to me.initial torque to get it turning will be higher.
Bob
03-21-2008 12:16:28
It sounds like you have the pistons installed, so it's PROBABLY normal. Are the bores well-oiled?
The crank, itself, should almost SPIN freely in the main bearings.
Does the crankshaft have a little endplay, and can you slip the indiviaual rods back and forth a little on the crank throws, in other words, they are NOT binding?
riverbend
03-21-2008 17:36:38
 Re: torque to spin crank with new bearings question in reply to Bob, 03-21-2008 12:16:28
I did not have the pistons installed, and found that the front main cap had a bright spot on the bearing. The plastigage had said it was okay the first time.
Re-cleaning the cap with a scotchbrite pad and rechecking gave 0.0015 for clearance. After oiling it and putting it together, it turned much better. Now (with pistons installed) it takes about 40 ft.lb. to get it started and 20 or less to keep it going.
Thanks guys
Greg
