1086 hydraulic problem
WarrenA
03-21-2008 14:10:08
I don"t have any oil flow to my implement control valves it seem like the oil is just dumping back into the reservoir anyone come across this
JayIHMan
03-22-2008 09:13:39
 Re: 1086 hydraulic problem in reply to WarrenA, 03-21-2008 14:10:08
Try taking off signal line on hyd pump, unscrew fitting and you will find a orfice-screen this needs to be removed to clean. If you have oil running out when you remove fitting chances are the orfice is clean. Also there is a signal check in priority remote that could broken worn/missing and there is a repair kit for this.
There is 2 orfices in casting on hyd pump housing that can cause low or no pressure on these systems.If you have a local Case dealer that has online parts lookup you will find the location of these orfices. Good luck
the tractor vet
03-21-2008 17:41:03
It all dependes on if it is the old style system or the later PFC system
WarrenA
03-21-2008 18:38:37
 Re: 1086 hydraulic problem in reply to the tractor vet, 03-21-2008 17:41:03
The tractor is a 1981 model how do you tell if is the older style or the PFC system
the tractor vet
03-21-2008 20:34:31
 Re: 1086 hydraulic problem in reply to WarrenA, 03-21-2008 18:38:37
That one has the pfc system , So this system i do not know that much about that system . As i only worked on one and that was a nightmare as i did not have the other pice for my flowrater to do the testing correctly . You may just have a speck of dirt in the orifice , a problem in the motor control valve . There is a whole list of could be's . If the pump is not getting a signal to move the swash plat then the pump may not be pumping . For this fix your really going to need the book and the Flow Rate and the analyzer to see just what is going on then you go from there. Sorry i could not be more of a help on this one.
Owen Aaland
03-21-2008 16:40:52
Either the relief valve is stuck open or there is an o-ring blown between the pump covet and rear frame.
