H Carb problems
dave Innerebner
03-21-2008 14:10:51
Hi I have an H with carb 6272DB. I have had problems with the carb for the last 7 years since we bought it. The carb has been brazed so I assume it was cracked. I have someone who will take it apart and clean it up and it runs great for a few weeks then it seems to always slip into a mode of leaking gas and what seems like running while flooding. This has been our plague for 7 years. I want to replace the carburetor and I find rebuilt 50981 DC carbs ebay. Can these different carburetors be interchanged? thanks,
dave
aaachris
03-22-2008 06:40:07
 Re: H Carb problems in reply to dave Innerebner, 03-21-2008 14:10:51
My SH does the same thing... I am going to try to polish the three side of the needle as soon as I get time and Ill post back to let you know how it went.
bc
03-21-2008 17:57:27
I'd look to buying one from this site. They may be easier to deal with getting the right one.
I don't know where it is leaking from, the brazed crack or out the intake. That is a common problem and a couple guys here have identified a problem with the needle valve needing a little sanded off of the three sides so it goes deeper into the seat and forms a better seal.
Andy Motteberg
03-21-2008 15:51:30
Yes, you can use the other carb, it will work fine.
rustyfarmall
03-21-2008 14:17:00
The two different models will readily interchange. No problem.
If you're buying it on ebay, ask lots of questions first.
