PTO seal replacemant
Ray Pell
03-21-2008 17:41:55
I am replacing the original leather seals with new IH seals on my A.The new ones are much slimer. When I replaced other seals that were this thick the replacements were a set of 2 put togeather. Has anyone replaced theirs lately?
Thanks Ray
Rex in Australia
03-22-2008 01:55:10
 Re: PTO seal replacemant in reply to Ray Pell, 03-21-2008 17:41:55
If you want to try an idea that i have used in the past. Put two seals in, back to back. The first in the normal direction, followed by another in the opposite direction. Put some grease in the cavity between the two if you wish. The idea is that the outer seal keeps the dirt out and protects the inner seal that is keeping the oil in.
All the best,
Rex
wellsy
03-21-2008 20:26:15
we just repaced the seal on the h today and we probaly just needed one but we put two of them in just to be safe
GA Dave
03-21-2008 18:01:49
After taking all this out I used one thin seal. Working fine. David.third party image
CNKS
03-21-2008 17:56:57
The original seals were leather. The thin replacements are much better. One is probably enough, you can use more. The outside seals will eventually wear out if you do not use grease when you install them, I don't know how much longer that makes them last. But cheap insurance.
Dave_Id
03-21-2008 17:49:07
Yes
