1466 tractor hydralics
gary eads
03-22-2008 06:52:35
i show all pressure in spec.but tractor has to have high rpm to raise equpement. the pressure was checked when tractor first started up.have took hydr. pump out and apart shows know ware and seams to be good any ideals
bc
03-22-2008 10:49:53
 Re: 1466 tractor hydralics in reply to gary eads, 03-22-2008 06:52:35
Is this something that it has been doing for years and you are just now asking or did it just start requiring high revs to raise the loader? Makes a diff in troubleshooting. What was going on when it started doing it? Are you in freezing country? A filter plugged with water can freeze at night and a solid chunk of ice may not unfreeze even though it gets above freezing during the day. Maybe adding up to 5 extra gallons of hytran may fix the problem. It sounds like flow/relief/supply issues if it works when revved up.
the tractor vet
03-22-2008 07:21:20
IF you have to rev it up to get any action i am guessing that it is the pump. Also with out testing the system with a Flow Rater you are still guessing as this system should be doing around 1750 lbs pressure at 12 gallons a min at rated pto rpm . Now the relief pressure could vary as to just relief is in that tractor . As sometimes people have installed higher reliefs . So my guesstimation is that the flow rate of that pump is down.
