Tie rod ends
GA Dave
03-22-2008 18:24:47
This should be easy but I can't figure out how to tighten one up on the outer end of my 240 U. I tried to put pressure on it with channel lock pliers but all it would do is spin the whole thing. Any ideas? David.
Brownie450
03-23-2008 03:19:03
 Re: Tie rod ends in reply to GA Dave, 03-22-2008 18:24:47
Use a wire wheel or paint remover to clean. Don't use heat.
Janicholson
03-22-2008 20:49:08
If you are tightening the tapered shank into the steering arm on the spindle, the threads must be boogered up. Take the nut off and clean up the threads, then make sure it seats into the taper. It should tighten against the taper W/O turning.
If it is a length adjustment, heating the tube may be needed, as they get rusted tight. JimN
GA Dave
03-22-2008 21:28:41
 Re: Tie rod ends in reply to Janicholson, 03-22-2008 20:49:08
It is the tapered shank and it's been painted. Time to burn the paint off? David.
Janicholson
03-24-2008 06:16:11
 Re: Tie rod ends in reply to GA Dave, 03-22-2008 21:28:41
Burning might not be best, I would use a wire brush. All parts can be toasted by fire. JimN
