Reverse idler in an M
Randy-IA
03-22-2008 19:07:07
Hi All , The transmission rebuild has moved to the final drive too . I'll probably have to replace the differential and axle bearings because of the crud that was in the oil . I might take the cheapskate way out for the the axle and bullgear pinion bearings and take them out of a parts tractor instead of buying new ones . I don't know yet till I get everything apart . I have a question about the reverse idler shaft . It has pits in it from rust . It only had minor play in the old bushings but I bought new bushings anyway ( Sticker Shock !! ) . I wasn't surprised at the cost of the bearings but the bushings I was ! The shaft was plugged with crud and I got it cleaned out as good as I can . I'm thinking of soaking it in carb cleaner overnight to be sure it's clean on the inside . I'm not to concerned about the rust pits . I feel that they will just hold that much more oil for lubrication . I was curious as to what everybody else thought about it ? I've shined it up with emery cloth . I still have to check the clearance of the new bushings . Hopefully it'll be snug without needing honing or to loose . One more question about the clutch throw out bearing . This one is tight . So is it OK to wash it off in a parts washer with commercial cleaner ? I'm not sure if it has any rubber seals in it I need to be concerned about . I haven't decided yet whether or not I'm replacing the clutch parts . I don't want to split the tractor to remove the flywheel to turn it and it needs turning if I put in a new disc . It has it's fair share of heat cracks . Thanks to all for any opinions ! ...Randy
Janicholson
03-22-2008 20:44:44
 Re: Reverse idler in an M in reply to Randy-IA, 03-22-2008 19:07:07
I'll address the Throwout bearing. Do not wash it. wipe it off good and ask your self if it is worth the hassle of pulling the bottom apart to replace it if it fails. Unless you are on a tight budget, I would replace it. The solvent will get into it. JimN
