m oil check
frank in texas
03-23-2008 16:57:55
I looked all over the engine block on my 1941 M and cannot locate an oil dipstick. How does one check oil on this tractor/ Any help on this one.
Bob Kerr
03-23-2008 18:30:34
 Re: m oil check in reply to frank in texas, 03-23-2008 16:57:55
Some may have had an aftermarket dipstick added to the oil pan. They usually have a round knob with the short dipstick built in on the upper side and a pipe plug added to the bottom hole.
Frank in Texas
03-25-2008 19:07:33
 Re: m oil check in reply to Bob Kerr, 03-23-2008 18:30:34
I thank you for this information. I've learned alot about my M from this forum. Thank You
HELPINING
03-23-2008 17:06:14
THERE ARE TWO PLUGS IN THE SIDE OF THE OIL PAN RIGHT HAND SIDE SITTING ON TRACTOR OPEN THEM THE BOTTOM ONE IS LOW ON OIL THE TOP ONE IS THE FULL FILL WITH OIL TILL STARTS TO SEEP OUT TOP PLUG
Frank in Texas
03-25-2008 19:05:28
 Re: m oil check in reply to HELPINING, 03-23-2008 17:06:14
I certainly thank you for the information. I'e got all the manuals but don't remember reading the part about this check just that it takes 7 qts of oil. Again, thanks
