C hydrolic pump and etc..
Johnny D
03-23-2008 19:27:34
Rebuilt the hyrdrolic pump and block. Block now has now leaks and all is good. Used the tractor this weekend with box blade and all the hydrolic oil ended up in the engine oil. No speedy sleeve was used in the pump because rebuilder said the seal fit snug. Should I bother rebuilding it again or just go for an expensive new pump. Also, is there any alternative gauges to use in place of the Shrader gauge used to set the stops for the arms on the hydrolic block or does anyone have any alternative suggestions to set the arm stops other than the directions in the IH-8 service manual. Thanks for any advice.
Janicholson
03-24-2008 06:27:46
 Re: C hydrolic pump and etc.. in reply to Johnny D, 03-23-2008 19:27:34
If you paid to have it rebuilt, I would present it to the rebuilder in a box an have it repaired by that person again on their nickle for labor. If the bearings are toast, the eseal will not hold. JimN
