F-20 right hand brake installation
Tom Fleming
03-24-2008 03:44:55
Ok, now that I bought paid and arm/leg for my F-20 right hand brake handle, how much disassembly is required to install it?
I could probably figure this one out, but thought I would ask first, and see if there were any "tricks" to save time/effort.
oldiron29
03-24-2008 04:04:48
 Re: F-20 right hand brake installation in reply to Tom Fleming, 03-24-2008 03:44:55
Tom, If you remove the wheel and remove the brake drum you will see the brake shaft. Remove the cottor pin and lossen the existing brake controls and you should be able to slide the shaft part way out install new handle and contols and slide shaft back in place. Replace drum and wheel and you should be good to go. Oldiron29
