FARMALL 140
DAN SP
03-24-2008 07:03:48
QUICK QUESTION WILL A SWING DRAW BAR FROM AN A FIT A 140 AND WILL THE BELT PULLEY AND SHEILD ASY
FIT A 140 TRACTOR? ALSO WILL A FRONT BLADE ASY MODEL 60 I THINK FIT A 140
Jim Becker
03-26-2008 18:09:58
 Re: FARMALL 140 in reply to DAN SP, 03-24-2008 07:03:48
To avoid problems with the pulley gear mesh (the shims), move the whole PTO from the A to the 140. You will need to use the tube that slides to engage the PTO from the 140.
The A swinging drawbar crossbar is not "quick attach" style. The holes on the ends are not slotted nor countersunk. You may be able to put it on the 140, but may not be as easy as it sounds.
DAN SP
03-25-2008 08:34:36
Thanks guys what I am trying to do is take a 1974 140 that I bought which comes with out a belt pulley asy or a swing bar bar, it does come with the draw bar also the 140 comes with out wheel weights I do have a 1945 A that has all of this so what I would like to do is bolt these pieces on to the 140 if they will fit? The front blade came off a super a tractor
Hugh MacKay
03-25-2008 17:34:12
 Re: FARMALL 140 in reply to DAN SP, 03-25-2008 08:34:36
Dan: That makes it a whole lot easier. Swinging drawbar tongue will work as you already have the U bar. It's only 39, 40 and 41 that PT0 and belt pulley are different. Probably not that long, but your safe with 45. Be careful with the belt pulley to get the shimes right.
Blade will be a direct bolt up, as will the wheel weights.
Hugh MacKay
03-24-2008 16:20:04
Dan: How much of the drawbar do you plan to use. U drawbar mounts to final drives differently on an A. Swinging drawbar tongue should be the same. Belt pulley from some of the first A tractors is different. Blade mounting will fit, however if the blade was hand lift that part will require some modification.
If this happens to be from a Super A all will fit, drawbar, pulley and blade all a direct bolt up.
TractormanNC
03-24-2008 16:14:23
Question 1 yes
Question 2 yes, but remember there were several different shields depending on whether you had PTO only, PTO and belt pulley, etc.
Question 3 I dunno
