wd9 front engine support zerk
JOE-ILLINOIS
03-24-2008 10:00:03
Hi, been servicing my 53 wd9, the book says there is a front engine support grease zerk but I'll be darn if I can find it, is it a plug to remove and put in a zerk or did they do away with them a use a sealed bearing, thanks Joe
Chuck46
03-24-2008 16:02:50
 Re: wd9 front engine support zerk in reply to JOE-ILLINOIS, 03-24-2008 10:00:03
Joe, All the older diesels have it, from the left side look on the cast mounting directly behind the crankshaft pulley, it is aimed upward at about a 45 degree. Good luck, Chuck
steelfronts
03-24-2008 11:26:20
No that is a grease fitting that is on the front motor mount near the center. I am not an engineer but they must a figured a little twisting was going to happen and thus the fitting. If you keep it greased maybe it will be easier to remove someday.Normally it seem like that hanger has to be pressed off the front cover
