Holy bejeebeez! Battery cable is expensive!
Mike CA
03-24-2008 19:32:39
$5.80 a foot for 1 ought for 7 feet! Plus all the ends I need to buy... plus the labor to have someone copper solder it!
Yikes! I had no idea!
Mike CA
03-25-2008 08:20:32
 Re: Holy bejeebeez! Battery cable is expensive! in reply to Mike CA, 03-24-2008 19:32:39
DCW said: Told ya.
My mom told me the oven was hot once. I had to touch it to really find out. :lol:
Tractorfan1
03-25-2008 08:20:20
I can get 1/0 welding cable for $3.29/ft or 2/0 for $3.99/ft...
DCW
03-25-2008 07:58:42
Told ya.
glennster
03-25-2008 04:55:25
yupper mike, i just made up a set of cables for my m. 72.00, cables ends, heavy duty terminals..wooo!!
nebraska kirk
03-24-2008 20:55:01
When scrap copper is worth near $3 a pound, anything copper is expensive! :-)
Mike CA
03-24-2008 20:46:15
Sounds easy enough Henry. I might give it a shot!
HENRY E NC
03-24-2008 19:56:39
Mike, your propane torch will solder that. Get a small roll of electrical solder (Not acid core), put the copper tip in the vise, heat it up, fill it 3/4 full of solder and stick the bare wire into the tip. Viola, its soldered. Henry
Mike CA
03-24-2008 19:44:52
tom Windsor said: Sorry...did not see it...
No worries at all Tom!
Tom Windsor
03-24-2008 19:36:36
You did not read my post....I told you I would send you some!!!!! !!
Mike CA
03-24-2008 19:42:09
 Re: Holy bejeebeez! Battery cable is expensive! in reply to Tom Windsor, 03-24-2008 19:36:36
Here you go, e-mail is open.
Thanks again Tom!
Mike CA
03-24-2008 19:40:41
Tom Windsor said: (quoted from post at 19:36:36 03/24/08) You did not read my post....I told you I would send you some!!!!! !!
I did! And I answered, and I e-mailed twice! :lol:
I went to go see how much it cost anyway, since I had no idea. I'm just more thankful than ever for your offer! :D
Please check your e-mail, or... I will go to classic view and open up my e-mail, in case you view through classic mode.
tom Windsor
03-24-2008 19:43:55
 Re: Holy bejeebeez! Battery cable is expensive! in reply to Mike CA, 03-24-2008 19:40:41
