Farmall Paint Suggestions?
Charles Todd
03-25-2008 19:44:29
I am restoring a 1962 Farmall 504D, S/N 3712, S-X-Y. I am in the process of fixing all of the issues before painting. Right now I have the remote valves tore down and bead blasted. I am trying Special Purpose Krylon® Farm & Implement Paint, Am. Beauty/Int'l Harvester Red
1818. The finish looks good and has a deep red color. Is this close to the period correct color?
I plan to base coat all painted parts with Krylon® and follow with a clear coat (undecided, but open to suggestions). Would this choice paint + quality clear coat produce a fairly durable and fade resistant coating? I have not decided on the white and silver yet. I am thinking of Krylon® Rust Tough® Rust Preventative Enamel, Gloss White
RTA9200 and either Aluminum RTA9213 or Silver Metallic RTA9232. I Also I plan to something like POR-15 on any bare surfaces to neutralize any possible rust.
This is not a show tractor. But If I go through and repair worn parts and make this a tight machine I want it to look good. I may go to the occasional tractor show or local parade. It will see light-medium use such as box blade, 10' tandem pull disk, bush-hog, flail mower, round baler, square baler, possibly a future 3pt stump grinder, and general loader work (dirt and hay spear). It will be parked indoors most of the time.
Thanks for reading,
Charles
HARLEY EAVES
03-26-2008 07:53:39
 Re: Farmall Paint Suggestions? in reply to Charles Todd, 03-25-2008 19:44:29
HAL, I LIKE THE GAS PUMP BEHIND THE W6, ALSO, THAT IS A GOOD PAINT JOB, MAYBE YOU WILL VOLUNTEER TO PAINT MY M WHEN I GET BACK TOGETHER.
HARLEY
El Toro
03-26-2008 08:32:12
 Re: Farmall Paint Suggestions? in reply to HARLEY EAVES, 03-26-2008 07:53:39
third party image
Here's a tiller I painted with the PPG 71310 paint code. Hal
PS: I plowed my garden on Tuesday and then tilled it.
El Toro
03-26-2008 08:25:52
There's a man & son in Ohio that painted those tractors. He is setup to power wash, sandblast and has a supplied air system when spraying that paint. Hal
bc
03-25-2008 20:06:49
According to the 1961 paint committee decision, the 504 was painted 201 harvester red and 901 harvester white.
CNKS
03-26-2008 07:14:03
 Re: Farmall Paint Suggestions? in reply to bc, 03-25-2008 20:06:49
I believe that the 404/504 is when IH changed to 2150 -- the 460/560 etc were painted with 201 which was changed to 2150 when the 404/504 came out.
CNKS
03-26-2008 07:26:39
 Re: Farmall Paint Suggestions? in reply to CNKS, 03-26-2008 07:14:03
The change to 2150 occurred on Oct 16, 1961.
Charles Todd
03-25-2008 20:16:11
Thanks bc, was that from the Wisconsion Socitey?
bc
03-25-2008 20:20:21
 Re: Farmall Paint Suggestions?-IH paint archives in reply to Charles Todd, 03-25-2008 20:16:11
It is from wisconsin history org. here is the website.
http://www.wisconsinhistory.org/libraryarchives/ihc/paint/
Mike CA
03-25-2008 19:50:51
I would recommend also asking this same question in the Paint and Bodywork forum, so you get a broad array of answers.
Charles Todd
03-25-2008 20:04:42
 Re: Farmall Paint Suggestions? in reply to Mike CA, 03-25-2008 19:50:51
Thanks Mike CA.
El Toro
03-26-2008 07:11:24
 Re: Farmall Paint Suggestions? in reply to Charles Todd, 03-25-2008 20:04:42
I would use PPG's 71310 Omni paint or its equivalvent and any of the major paint companies can cross-reference this number. There's a family in Ohio that paints a lot of tractors and they use Martin Senours Crossfire paint. Here's several of the tractors they painted. Hal
third party image
third party image
hagen
03-29-2008 20:00:50
 Re: Farmall Paint Suggestions? in reply to El Toro, 03-26-2008 07:11:24
Hey El Toro.....where at in Ohio?
