7130 with slow hydralics
chucky
03-25-2008 22:33:32
We have got a 7130 with a loader on that is very slow operating. The loader/tractor combo will lift a house but is slow doing it. I check the flow control cable that are down on the side of the tractor on the controls and they seem to be moving freely but the loader moves at the same speed no mater where the flow control is set at.
I replaced the hydralic filter under the cab and cleaned the screen in the trans(found nothing).
Now I'm wondering what could be wrong?? I've got lots of pressure but no volume.
Thanks Chucky
JayIHMan
03-26-2008 16:59:37
 Re: 7130 with slow hydralics in reply to chucky, 03-25-2008 22:33:32
7100 series Magnums had issues with flow controls, check and see if set screw has came out where flow control cable meets the flow control. Manually turn stem of flow control while under unit it is probably stuck in brass packing nut. Be carefull this can get expensive if you get to rough with flow control. Case does offer a replacement flow control and spool if you break it for about 400 dollars. Good Luck
