560 help, Thanks
UncleBubb*IH
03-26-2008 08:57:25
I finally got started on the 301 for our 560, the tractor has been sitting in a corn crib for about 15 years. I need to know if the hydraulic system will have any problems through condenstaion and so on, it hasnt been open, its all tight, what should I expect?
Bubb; Keep the dirt flow'n and the smoke blow'n!
ejr-IA
03-26-2008 13:41:22
 Re: 560 help, Thanks in reply to UncleBubb*IH, 03-26-2008 08:57:25
Diesel fuel is what I used but that stuff is expensive to use now.Pour it in where you add the hydraulic fluid at least 5 or more gallon and rock the tractor back and forth and slosh it around in the transmission and drain it.
ejr-IA
03-26-2008 09:22:14
I would drain flush and new filter after that many years of setting.
UncleBubbIH
03-26-2008 09:38:36
 Re: 560 help, Thanks in reply to ejr-IA, 03-26-2008 09:22:14
What would you recomend for flushing.
