Manifold stack pipe
Tims A
03-26-2008 09:19:04
Is there any reason I should not use a galvinized stack pipe in my A's manifold? I already have one Galvinized. Corrosion issue here?
Thanks Again
Tim
HossinMe
03-26-2008 15:58:04
 Re: Manifold stack pipe in reply to Tims A, 03-26-2008 09:19:04
Drink milk before running,stops you from getting sick.This is what we do when welding the crap. Later, Hoss
Dave S.
03-26-2008 15:49:31
The galvanized pipe will work ok but as the others said the poisonous fumes off of the galvanizing when it melts can make you real sick or even kill. I would get a black pipe to be safe. Dave
Don L C
03-26-2008 12:17:35
Tims A ---
A galvinized iron pipe may be to heavy to use all the way up.....could shake and break the manafold.....you could use it to come up through the hood, then go with tubing or a muffler....
Steven f/AZ
03-26-2008 11:57:39
As others posted, harmful fumes while the coating burns off... then you're left with a black pipe anyway. Black pipe is cheaper.
Bob M
03-26-2008 09:57:11
The first time you work the tractor with the galvanized pipe stack it will turn into a plain old black iron pipe. (The zinc galvanizing quickly melts/burns off at normal exhaust temperatures...)
Go ahead and use it. But as Jim suggests below don't be breathing the fumes until all the zinc has disappeared!
Janicholson
03-26-2008 09:46:54
Zink is a toxic metal when oxidized. It discolors and may not be visually as nice as desired. If kept down wind while burning off, no real issue. JimN
