finding a 330 Utility transmission drive shaft spacer
mdaitc
03-26-2008 16:40:28
Hi,
i've got my 330 apart, trying to fix a leak, and it looks like the transmission drive shaft spacer (360495R1) has a groove worn into it under the seal. (Page 122 on the Case IH parts site). Unfortuantely, it's retired, and no longer available...
does anyone know of a source where i might be able to get one?
thanks,
mdaitc.
mdaitc
03-26-2008 18:04:53
 Re: finding a 330 Utility transmission drive shaft spacer in reply to mdaitc, 03-26-2008 16:40:28
thanks for the idea on the sleeving. i've already tried my local parts dealer, and searched on the website for the part number, but i don't seem to be able to find the ability to search for parts without selecting a model
CNKS
03-27-2008 07:25:43
 Re: finding a 330 Utility transmission drive shaft spacer in reply to mdaitc, 03-26-2008 18:04:53
Look at the 300 and 350, possibly the 340.
CNKS
03-26-2008 17:29:53
Although I am not familiar with that particular tractor or part, you probably have 3 choices: 1. A speedi sleeve or redi sleeve (both trade names) 2. see if you can move the new seal to a different position (probably not likely), or 3. have the groove filled by a machine shop that is familiar with the procedure to do it right. Don't simply have it brazed. Or--try to find parts in a salvage yard. In that case compare part numbers on the Case-IH web site-caseih.com to give a wider range of tractors to look for.
