560 Hydrualics
ITFormulaGuY
03-27-2008 06:33:57
Can someone send me a picture of where the Hydrualic pump is located on the Farmall 560 Gas. Hydrualics were working fine, i serviced the tractor put new oil and filter in place and after using the loader to load some scrap metal the hydrualics are almost non-exsistant. There is not enough power to lift a disk or the loader. the slower you run the tractor the more the hydrualics seem to work but are still useless. if you run the engine at a higher idle the weaker the weaker the hydrualics are and leak down very quickly. Any tips or insight would be great as i am used to H's and M's! Thanks again!
ITFormulaGuy
04-23-2008 08:52:51
 Re: 560 Hydrualics in reply to ITFormulaGuY, 03-27-2008 06:33:57
ok back again. i was talking with a friend of mine and he said it sounded like a relief valve was stuck open. Looking at the IH website and parts diagram i"m not seeing a "relief valve" in the parts list. Does anyone know if there is one in the 560 system and where it would be and how to check it?
thanks again!
ITFormulaGuY
03-27-2008 09:38:57
the IH website is just what i needed. hope i can figure it out from here!
Rootsy
03-27-2008 09:03:06
Left side of tractor directly across from the filter. Beneath the cover that is behind the clutch & TA linkage.
When you replaced the hydraulic fluid you did you Hytran didn't you?
ITFormulaGuY
03-27-2008 09:31:01
 Re: 560 Hydrualics in reply to Rootsy, 03-27-2008 09:03:06
yup, hytran.
neblinc
03-27-2008 06:48:08
Go to the CaseIH web site and do a search for parts.
Type in Farmall 560 and you will get a complete parts breakdown.
Randy
