806 ticking sound in the rear of the tractor
IH Nate
03-27-2008 07:16:39
I have a ticking sound in the rear of my 806. The sound speeds up with rpm's and is noticeable whether the tractor is moving or not. It is not a loud sound, but you can hear it from the seat. It sounds like it is coming from the left henad side of the tractor just behind the step. Is it a pump of some kind, and is it a sign that something is going out? Any help would be appreciated. Thanks
Owen Aaland
03-27-2008 07:19:45
 Re: 806 ticking sound in the rear of the tractor in reply to IH Nate, 03-27-2008 07:16:39
The location where you say you are hearing the noise is where the rear hydraulic pump is located. I would guess you either loose gear on the pump shaft or a damaged gear.
