Janicholson is this it?
tn terry t
03-27-2008 21:01:02
third party image
is this the knob that you were talkin bout the other day? it has D and S stamped right below the knob. if it is what would you do to keep the draw bar up to pull the hay rake?
tn terry t
03-28-2008 15:37:37
 Re: Janicholson is this it? in reply to tn terry t, 03-27-2008 21:01:02
thanks guys thats what i needed to know that will get me started!
RAW in IA
03-28-2008 15:03:49
I missed the first post you made, but are you talking about a fast hitch? If so, dad's 350 had a couple of loops(?) up by the rockshaft that yuou could take the lift rods off the lift arms and hook them up to. this would hold the drawbar in one position and not depend on the hydraulic cylinder to hold it.
Janicholson
03-28-2008 12:46:55
That would be it.
If the cylinder on the hitch has quick couplers, it should stay where it was. Do not trust it the first time you disconnect. JimN
tn terry t
03-28-2008 05:59:33
 Re: Janicholson is this it? in reply to DCW, 03-27-2008 21:01:02
thanks Gary what we where talking about was to dis connect the hosesfrom the cylinder on the back of the tractor and turn that knob to hook up a single acting cylinder that is on the wheel rake i have . so what your saying is if i disconnect the lift it should stay in place if the lift cylinder is good. huh makes sence to me . I think lol :shock:
IaGary
03-28-2008 05:04:03
That valve sets the hydraulic in either Double on Single way pressure.
D For two way pressure "double"
S for "single" way presure.
If your draw bar leaks down your cylinder may need to be rebuilt.
Gary
