1942 M large oil filter
Dick fm Iowa
03-28-2008 04:16:02
Buddy has a 1942 serial numbered M with the 1939 size oil filter. When did they start putting the smaller diameter filters on M's. I wonder if someone just bolted on an old style filter? Thnks for you insights. Dick Davis
RustyFarmall
03-28-2008 08:31:30
 Re: 1942 M large oil filter in reply to Dick fm Iowa, 03-28-2008 04:16:02
There appears to be some confusion here. The early Ms used an oil filter that was much bigger, not to be confused with the later tall filter that was shared with the early H. The later Hs used the short filter, the later Ms still use the tall filter, but it is not as large in diameter as what was used on the early M.
Dick fm Iowa
03-28-2008 13:42:19
 Re: 1942 M large oil filter in reply to RustyFarmall, 03-28-2008 08:31:30
Rusty - you are right I did open a can!
When I referred to 1939 size filter I meant the one about 6" in diameter as opposed to the later ones that where about 4" in diameter in both short and tall heights. Anyway sorry I asked. Dick
Steven f/AZ
03-28-2008 08:08:29
I have three 1942 H's... 101816 and 101821 have the tall filter (along with flat PTO housing, and no pressure radiator) while 122068 has the short filter, longer PTO housing and pressurized radiator...
I suppose that many changes took place in '42. But I've also seen plenty of later tractors with the tall filter...
Curt W.
03-28-2008 06:51:24
My 47 M has the large filter. I think the H changed in 41 or 42. We have a 41 H with a tall and a 43 with a short. Not sure about the M though.
CNKS
03-28-2008 06:50:15
SN 59394. Very late 1942, Check the CaseIH web site for verification.
glennster
03-28-2008 06:28:22
my 42 and 48 m both have the big filters on em. im not sure when the cut off date was that they changed over to the little filter.
