Farmall H Carb
MJ in the UK
03-28-2008 05:32:39
Hi folks, could you please tell me the float height setting. The tractor is a 1945 H with an IH carb. The reason i want to check the setting is because the tractor runs fine but it needs 5 or 6 cranks opn full choke to start it and when it is pulling hard up a hill it seems to get fuel starvation. I also want it to start well as this tractor has no electrics as it was a lease lend tractor. Many thanks, MJ
Mike CA
03-28-2008 07:32:43
 Re: Farmall H Carb in reply to MJ in the UK, 03-28-2008 05:32:39
MJ, if you can give me an e-mail, I will send you the float adjustment instructions I have.
Mike CA
03-28-2008 07:31:48
MJ in the UK said: Hi folks, could you please tell me the float height setting.
I have them at home. You will need a 1/64th ruler to properly measure it.
Don L C
03-28-2008 06:11:44
MJ ---
The setting is 7/8" If you need a Service manual....IHC copies Binder Books 503 684-2024
Don
GordoSD
03-28-2008 12:36:58
 Re: Farmall H Carb in reply to Don L C, 03-28-2008 06:11:44
7/8" is the distance of the fuel from the gasket when shutoff occurs. 1 27/32 is the measurement for the float.
Gordo
