Power steering on M
Bernie Steffen
03-28-2008 15:09:04
Question for alan in NE. Was told You just finished power steering on your M. I just bought a used Char-lyn for mine. I can"t figure out how the pump installs and where it drives from. Any help appreciated. Bernie Steffen
Steven f/AZ
03-29-2008 05:52:28
 Re: Power steering on M in reply to Bernie Steffen, 03-28-2008 15:09:04
OR, if you want full-on live hydrualics right away, you can have a machine shop fabricate a crankshaft pulley and buy a bigger pump... of course it would hang off the other side on an M.
third party image
Allan In NE
03-28-2008 16:53:30
Berrnie,
Like Steven says, there were two or three different kinds of setups on those Charlynns with differing mounting brackets.
Mine is the old one that went on the M. Bolts to the governor cover and needs the extra pulley down on the crank to twist it.
Allan
third party image
Farmer Bob
03-28-2008 15:45:54
third party image
Or, as this bracket allows, just need a longer gen/alt belt and run it off the upper fan belt pulley.
Bernie Steffen
03-29-2008 06:59:32
 Re: Power steering on M in reply to Farmer Bob, 03-28-2008 15:45:54
Okay I have it figured out now. I just wondered if anybody knows what size belt the high mount pump takes? Off the water pump and alternator. Any and all comments and ideas appreciated. Bernie Steffen
karl f
03-28-2008 21:29:58
Farmer Bob said: (quoted from post at 15:45:54 03/28/08) Or, as this bracket allows, just need a longer gen/alt belt and run it off the upper fan belt pulley.
if you cannot find an original charlyn pump, this setup probably is easiest to mimic to use a common GM or Ford pump. or should i say HIDE the GM or Ford pump.
karl f
Steven f/AZ
03-28-2008 15:22:18
There is a bracket that installs on the governor housing and a pulley that goes on the crankshaft with a roll pin. Direct belt drive from the crankshaft.
