Farmall C Transmission Fluid
Greg 2010
03-28-2008 19:15:22
I have had the tranny opened up on my 51 Farmall C. The oil was really dirty so I drained it and cleaned the transmission. I am wondering now what type of oil and the weight that I need to put back in. Also what is the capacity of the transmission. Your help is appreciated.
gene bender
03-29-2008 03:07:57
 Re: Farmall C Transmission Fluid in reply to Greg 2010, 03-28-2008 19:15:22
I like the 150wt.
ScottyHOMEy
03-28-2008 19:20:59
90 or 80-90 gear oil. Some folks use heavier to quiet it down. Okay, as long as it's not too cold where you are.
It'll take a five-gallon pailful.
CNKS
03-28-2008 19:23:24
 Re: Farmall C Transmission Fluid in reply to ScottyHOMEy, 03-28-2008 19:20:59
Unlike the A, SA, etc, the C transmission is very quiet. I probably should have said 80W90 like you did as the 85W-140 is overkill.
CNKS
03-28-2008 19:20:32
90 or 85-140. 4.75 gal/5 with PTO. Fill to the plug on the right rear of the differential housing. And there are many things in the Operators Manual you need to know. www.binderbooks.com
