Super H serial number looks doctured
Sleepy
03-29-2008 18:41:49
Im inquiring with a fella about a super H with the following serial number. SH48028J
Acording to all the lists I have found, this number is wrong. While I have not seen the tag yet, Im wonduring if it may have been doctured.
Anyone have any ideas?
Thanks
Sleepy
sleepy
03-31-2008 06:24:19
 Re: Super H serial number looks doctured in reply to Sleepy, 03-29-2008 18:41:49
The man says that he acquired the tractor years ago and knows nothing about serial numbers on old Farmall tractors. I will check the casting numbers.
Thanks
Sleepy
mkirsch
03-31-2008 10:21:52
 Re: Super H serial number looks doctured in reply to sleepy, 03-31-2008 06:24:19
Why immediately go to the tag being "doctored?" There are plausible explanations why the number doesn't jive:
1. He's dyslexic and is mixing up the order of the digits.
2. The tag is hard to read, and he's interpreting the numbers incorrectly. It could easily be 18028J, or 4802XJ.
3. He's giving you the serial number from the wrong tractor. Maybe he's got a Super M too, and got the two serial numbers mixed up in his head.
Before you all start accusing the man of being a liar and a thief, get the numbers off the engine and castings. Heck, go look at the tag in person.
DCW
03-29-2008 19:35:15
Look at the casting letters on all the major components and see if their the same,then check the letter,that will give you the year,approximately.
If its a true Super H,the letters will be X,Y,OR Z ON THE CASTINGS.
CNKS
03-29-2008 18:45:58
SH Serials are from 501-29285. Dib't know why anyone would change it to a number completely out of that range -- ask the guy to look at it.
Vito
03-29-2008 18:43:30
Have him give you the serial# stamped on the engine block
Vito
