wd9 value
dwsc
03-30-2008 11:20:41
what would a wd9 be worth the sheet metal is very good, tires are fair to poor, the owner says it will not run on diesel, he started having this problem after changing the filters, I'm thinking that he didn't get it bled out good enough, it will run on gas.
mulcher
03-30-2008 16:53:25
 Re: wd9 value in reply to dwsc, 03-30-2008 11:20:41
We gave $400 for a WD9 with bad tires and the engine was stuck. We wanted the wheel weights, injector pump and the M&W hydraulic pump.
Brian
D-C-741
03-30-2008 16:17:27
My Brother has the same engine out of a TD 9 Loader [knocks,has extra parts to fix ]it's going for scrap wedsday,Call 607-760-4771 if some one needs it/ I am near Elmira,NY
Janicholson
03-30-2008 15:32:13
AS you describe it, I would place a top dollar at 1000. They ar interesting tractors, and powerful. but not handy, and not (opinion) ergonomic to me.
The tires are a 8 to 900$ issue, so that makes it difficult to get excited. It may have nothing wrong but bleeding the injectors to get it operational. But if it does, then trouble is waiting. JimN
pictures please
03-30-2008 12:06:51
pictures will help, but still not an easy question. How bad do you want it? How bad does the seller want to sell it? and on and on and on, even then, YOU have to decide.
