bad injector?
l awrence
03-30-2008 18:21:00
my b414 diesel seams to choke on fuel only somtimes lots of smoke, and a miss then a stall, the starter has trouble turning over the engine. wait about 30 min.then ok.any advice out there, thanks in advance
the tractor vet
03-30-2008 20:37:51
 Re: bad injector? in reply to l awrence, 03-30-2008 18:21:00
I am not up on that engine to call myself a GURU on it but first make sure that you have unrestricted air flow . Then i would pull the injectors and have them checked . Just because it is a diesel does not mean that they don't need TUNED up once in awhile.
Charles Todd
03-30-2008 19:24:06
My D188 misses lightly once started, then clears out after 30-60 sec. Also under heavy load, it misses... I wonder if I need to have my injectors overhauled?
