Re: field circuit resistance on Farmall B
Bob M
03-31-2008 05:10:37
third party image
Here's a backside view of a switch as on your B. The field resistor is the wirewound unit at the bottom. Seems to me the correct resistance is 3 or 4 ohms - however I'm only going from memory here...
However if it were mine I'd replace the cutout relay with a voltage regulator. The V/R will do a much better job of maintaining the battery, and it will eliminate the need for the field resistor.
I believe the fuse is an SFE 10 (glass tube type, 10 amp). However later letter series and Supers used an SFE 20 (20 amp) fuse - that's what I recommend.
