Order Farmall Cub Parts Online
Cub Lo-Boy Fan Assembly Yoke
Lee Brown
03-31-2008 05:21:39
I started my Cub lo-boy the other day and heard a noise, which was the fan belt cutting into the radiator. Upon further inspection, the yoke (made of cast) had been brazed sometime before (I got it at an auction 2 to 3 years ago), so it broke again.
So now I need to find the parts (the cast yoke assembly, fan, and radiator). Does anyone know of a source that is reasonably priced and close to the northwest part of Virginia?
Thanks a lot!
Lee
Lee Brown
04-01-2008 05:14:56
 Re: Cub Lo-Boy Fan Assembly Yoke in reply to Lee Brown, 03-31-2008 05:21:39
Thank you both for your insight and advice! Now I know what I'm dealing with and what parts I'll need to get. I appreciate it!
Lee
Haas
03-31-2008 18:04:21
 Re: Cub Lo-Boy Fan Assembly Yoke in reply to Haas, 03-31-2008 17:57:23
Did not mention above, but you have to pull the crank pulley to replace the support for the fan pulley. The support is part of the front engine cover. That is why is was brazed instead of replaced. While you are into it, also get yourself a new front engine seal since the seal is mounted in the front engine cover. To do the job properly, you will also need a new front cover gasket.
Haas
03-31-2008 18:03:46
evilboweviel
03-31-2008 13:30:47
Link
has them on the shelf
ron
