460/560 Head
Vapet
03-31-2008 05:59:13
Doing some head work on a 560D. Have a 460 parts machine and want to know if the 460 head will work on the 560? Checked online parts manual and they do have different numbers. Thanks
Jim J
03-31-2008 19:12:20
 Re: 460/560 Head in reply to Vapet, 03-31-2008 05:59:13
The head will work. I've taken 460 heads off of 560's when I ran the salvage yard.
ihc49er#2
03-31-2008 19:09:17
the pistons are the same in both engines, because i have used the 560 ones in a 460.i am going to measure the block height tommorrow.i am positive it is shorter.
ihc49er#2
03-31-2008 08:06:13
i have used a 560 head on a 460, they are basicaly the same eng.the 460 has a shorter stroke.if i remember right the block is also shorter than the 560 block.
Owen Aaland
03-31-2008 08:20:51
 Re: 460/560 Head in reply to ihc49er#2, 03-31-2008 08:06:13
Both engines use the same block. The 560 pistons have the piston pin located closer the the top of the piston to compensate for the longer stroke.
Vapet
04-01-2008 07:19:03
 Re: 460/560 Head in reply to Owen Aaland, 03-31-2008 08:20:51
Thanks everyone
