Delco distributor Rotor free play
Andrew Z
03-31-2008 09:34:39
does anyone know how much play is normal in these dist. ? Im working on an M and it has i would say about 20-30 degrees of play in the rotor. I looked at the IH dist that i have and they have play in them but the rotor "spring" back to a point. This one does not do this at all and i was wondering if the springs on the weights in the dist are shot, but i have no idea about these delco dist.
Thanks for the help
Andrew
riverbend
03-31-2008 14:28:22
 Re: Delco distributor Rotor free play in reply to Andrew Z, 03-31-2008 09:34:39
I don't have a parts book for an M, but advance springs for an H are available. It might also be that the auto advance is just full of rust.
A problem that I have seen on my tractors is that the rotor is a poor fit on the distributor shaft. A thin shim (originally a section of aluminum dryer vent) removed the slop.
Greg
Janicholson
03-31-2008 09:38:40
The springs are toast. They can be found, but the specific tractor's curve must be matched, or they will work poorly. The shaft pivot point should be lubed with a PTFE based synthetic oil (small tube oiler) after cleaning. JimN
Andrew Z
03-31-2008 11:50:11
 Re: Delco distributor Rotor free play in reply to Janicholson, 03-31-2008 09:38:40
Thanks Jim, thats what i thinking.
Andrew
