info needed on an international I6
frkln
04-01-2008 20:59:02
ok, found an older international i6 with a front end loader. i cant seem to find any information for the tractor... horse power, size, weight, etc etc etc.
can anybody shed some light on the subject? or any links for additional info.
thanks
frkln
04-02-2008 06:59:49
 Re: info needed on an international I6 in reply to frkln, 04-01-2008 20:59:02
never mind!!! i feel like an idiot!!!! i found it on johns web sight. 8.99, but its sold out! but i did order the wife the Passenger Noise Reducer!!! lol
Andy Motteberg
04-01-2008 21:36:32
Manufacturer: International Harvester
Model: I-6
Type: Industrial tractor
Years produced: 1940 - 1953
Total built: 28,378
Factory: Rock Island, Illinois, USA
Original price: $2,400 (1953)
Tractor power: Drawbar (rated): 32.97 hp Drawbar (max): 32.5 hp PTO (rated): 44.2 hp
DISTILLATE ENGINE: Fuel: distillate
Type: vertical I-head
Cylinders: 4
Bore/Stroke: 3.875x5.25 inches
Displacement: 247.7 ci Compression: 4.75:1
4.5:1 (kerosene)
Rated RPMs: 1450
Cooling: liquid
Firing order: 1-3-4-2
Sparkplug gap: 0.025
Point gap: 0.013
GASOLINE ENGINE: Fuel: gasoline
Cylinders: 4
Bore/Stroke: 3.875x5.25 inches Displacement: 247.7 ci Compression: 5.65:1
Rated RPMs: 1450
Cooling: liquid
Transmission: Type: sliding gear
Forward: 5
Reverse: 1
Capacity: Fuel: 21 gal Aux. fuel: 0.88 gal Coolant: 25 qts
Tires: Ag front: 6.00-16
Ag rear: 15-30
Dimensions: Weight: 5515 lbs Length: 124.4 inches
Width: 63 inches Height: 91 inches
Nebraska Tractor Test 354: Test Date: September 1940
Engine: distillate
Belt (max): 34.2 hp Drawbar (max): 30.7 hp Nebraska Tractor Test 355: Test Date: September 1940
Engine: gasoline
Belt (max): 37.0 hp Drawbar (max): 32.5 hp
Hope this helps!
Andy.
frkln
04-01-2008 21:44:27
 Re: info needed on an international I6 in reply to Andy Motteberg, 04-01-2008 21:36:32
andy,
no i dont think all that information helps me at all.... i think you forgot the size of the muffler bearing!!!!!
man thanks alot!!!! that is great!!!!! thanks again!!!!
do you happen to know of any general problems with the tractors? are they good, bad, or?????
and thanks again
Andy Motteberg
04-02-2008 18:20:34
 Re: info needed on an international I6 in reply to frkln, 04-01-2008 21:44:27
What do you mean by "muffler bearing"?
frkln
04-02-2008 19:06:06
 Re: info needed on an international I6 in reply to Andy Motteberg, 04-02-2008 18:20:34
what???? you never heard of muffler bearings, blinker fluid, woberlator valves... etc etc... lol lol
John M
04-02-2008 03:37:07
The engine is the same as an M so parts will be easy to come by for the most part. Shhetmetal may be a little tough to get if you need it, other than that they are a pretty stought little tractor. For the odds and ends, like muffler bearings, you can get them at the link!:)
frkln
04-02-2008 05:56:29
 Re: info needed on an international I6 in reply to John M, 04-02-2008 03:37:07
now that is funny!!!!! i have seen it all!!! next your going to say you have a link for turn signal fluid!!!!
rhouston
04-02-2008 11:54:29
 Re: info needed on an international I6 in reply to frkln, 04-02-2008 05:56:29
Blinker fluid is listed on their site. You may want to check the specs but I think it is also rated for flashers.
gene bender
04-02-2008 06:28:57
The fluid is harder to get as K-MART dont have any BLUE LITE specials.
