International 484 clutch
James westingho
04-02-2008 13:59:36
Hi, my clutc is making a chattering noise when in netural. What do i do is it time for a new one???
Mich John
04-03-2008 07:52:39
 Re: International 484 clutch in reply to James westinghouse, 04-02-2008 13:59:36
Does the neutral rattle (with clutch out) occur more frequently (or with more intensity) when the tractor is warmed up? Does light foot pressure on the clutch pedal cause it to go away - if so, it just might be "gear rattle" which is not nice to have but it does NO harm o/wise. Many factors go into this issue but poor engine idle quality, worn clutch disc, low viscosity trans gear oil, etc can aggrivate it. If NOT described as above, look for other causal factors.
mkirsch
04-03-2008 06:48:05
Have you adjusted the clutch recently? You might want to try that.
JimB2
04-02-2008 18:59:01
Hi James, have a 454 that has been doing the same thing for years. We replaced clutch, throwout and release bearing and still does it. If you lift the Hi/Lo/Rev shift lever slightly above the N position does the rattle stop?
Also the rattle is more noticeable if the range transmission is in 3rd or 4th gear.
JimB
Kevin Meier
04-02-2008 16:28:45
probably a dried out release bearing
karl f
04-02-2008 15:33:36
we have a bad ignition switch on the 685. when you push the clutch in sometimes it sounds like bad things are going on with the clutch.
(on ours) It's actually the starter trying to engage the flywheel that"s already turning. quick test: wiggle the key switch with the clutch pressed in and it goes away. hope this helps you before you tear open the tractor.
karl f
495man
04-02-2008 14:21:46
Does it slip under load? i.e. in high range going down the road, might be noisy input shaft???
James Westinghouse
04-02-2008 18:34:31
 Re: International 484 clutch in reply to 495man, 04-02-2008 14:21:46
it only chatters when clutch is released and tractor is in neutral
James Westinghouse
04-02-2008 18:14:04
No it doesnt slip at all Thank you
