Help!!!! 450 Temp. gauge bolt broke in block
Bill Thompson
04-03-2008 05:36:34
I got a new IH temp gauge for my 450. Thinking I could just insert the new prong into the old nut in the block, Stupid Me what was I thinking it would be that easy. Went to take out old nut it sheared off at the block with maybe 1 1/2 theads sticking out.It is not threaded on the inside for easy out. Can I take a hack saw blade and carefuly cut it out? The old nut is very thin. The new one is twice as thick.
Bill Thompson
04-04-2008 05:54:53
 Re: Help!!!! 450 Temp. gauge bolt broke in block in reply to Bill Thompson, 04-03-2008 05:36:34
Thanks! It worked. Put the new one in and ran it for 45 min. needle got to the L in cold. No leaks. Thanks Bill
ChasK
04-03-2008 10:17:22
[quote="Bill Thompson"] Went to take out old nut it sheared off at the block with maybe 1 1/2 theads sticking out.quote]
If there is still that much sticking out, would it work to stick a bolt into it and clamp on with a Vice-Grip?
jal-SD
04-03-2008 05:59:11
Cut it part way w/hack saw blade, but not so far that you run too far into the threads, use a fine punch or chisel to collapse what is left of the nut on both sides of your cut, take a needle nose, grab one of the "ears" that you have built & screw the nut out. (Sometimes before you get the second ear "built", whats left of the nut will fall out.) Clean up the threads & screw the new nut in. I'd cut as close to the longest part of what's left of the nut as possible, so you have someting to start the chisel on. (My $0.02 worth. jal-SD)
Nebraska Cowman
04-03-2008 05:47:29
I'd probably use a small chisel or a punch sharpened on one side. If it is thin like a pipe fitting it should come out easy enough.
