Mark Carey H ?
55 50 Ron
04-03-2008 07:58:03
Mark, Did you get your "H" to charge? Does it have a magneto or distributor ignition? I would expect a magneto based on your other posts. If it has the magneto that would help explain why there is no small wire from the ammeter to battery. Someoone may have taken that wire loose and just plopped a 12 volt batttery in there for starting only, since as someone else posted, it will start many times on a 12 volt battery without need for re-charging.
Mark Carey
04-03-2008 14:39:16
 Re: Mark Carey H ? in reply to 55 50 Ron, 04-03-2008 07:58:03
yeah it does have a magneto on it. Thanks for the help. Im going to tinker around with it and if I dont get it to start charging I'll let you know
