Super H wide front FIT 300 row crop ???
Sam F.
04-04-2008 11:44:25
I just picked up a Super H with the wide front axle. It has the steering arms out front. Will this fit my 300 single wheel row crop ?? Would this tie rod configuration be the right one or does the 300 use the tie rods behind the axle. Thanks for any help and advice.
Andy Motteberg
04-04-2008 12:06:48
 Re: Super H wide front FIT 300 row crop ??? in reply to Sam F., 04-04-2008 11:44:25
It will fit on the 300, but is not correct. The 300 Farmall has the tie rods behind the axle.
Sam F.
04-04-2008 12:55:22
 Re: Super H wide front FIT 300 row crop ??? in reply to Andy Motteberg, 04-04-2008 12:06:48
What size of tires should it use, 5.50 or 6.00 x 16 ???
Andy Motteberg
04-04-2008 13:29:31
 Re: Super H wide front FIT 300 row crop ??? in reply to Sam F., 04-04-2008 12:55:22
The 300 originally used 5.50.16" tires, but you can still use the 6.00.16" tires.
Andy.
CNKS
04-04-2008 13:26:12
It doesn't make much difference, our H had 6-16 6 ply.
Steven f/AZ
04-04-2008 11:58:59
Not the "correct" tie rod configuration, but it will bolt right up no problem!
