Carb help
Eri k H
04-04-2008 15:45:41
Om my '46 K-3 truck, the bottom plug on the carb is stripped(the bowl-not the plug), it will hold gas, but leaks it on the manifold- in the sense that I can run it a little, but keep a can under the carb. Any ideas on a fix? I hate to get another carb when this one runs so nice.
Janicholson
04-04-2008 16:24:41
 Re: Carb help in reply to Eri k H, 04-04-2008 15:45:41
Very tiny thread inserts are available that can be screwed into a new tapped hole, then seated with thread locking tabs, or cemented in place. Fastenall probably, or motion industries. JimN
bc
04-04-2008 15:50:43
One possibility, other than re-tapping the threads or drilling it out, and retapping it to the next size plug, is to put JB weld on the plug and screw it in(permanently). Someone else may have a better idea.
