Battery Going Dead Multimeter Question?
Larry Ed
04-04-2008 17:30:21
To most this will sound pretty simple, but it's new to me. My battery is going dead too quick I think. How do I tell with my multimeter if there is a drain on my battery? How do I tell with the multimeter if the alternater is putting out? Thanks, everyone. Larry
HAS
04-05-2008 06:47:47
 Re: Battery Going Dead Multimeter Question? in reply to Larry Ed, 04-04-2008 17:30:21
What I do is charge the battery with the battery charger, then disconnect the charger and read battery voltage. It should be about 12.8 volts, just under 13. Keep the meter on the battery while you start the engine. During starting the battery reading should not drop below 10 volts - if it does you have a bad battery. After starting you should read at least 14 volts or the alternator is not charging.
