Farmall F12 starter
James Williams
04-05-2008 05:10:56
I finally figured out a starter system for my F14,Looks orginial and works very good,Im finally happy.With a little thought and scroging parts any thing is possible
jimmy
Steven f/AZ
04-05-2008 15:04:14
 Re: Farmall F12 starter in reply to James Williams, 04-05-2008 05:10:56
Thanks for the added info! It gives a person a place to start.
Steven f/AZ
04-05-2008 08:37:33
Pictures? Parts required? Better explanation of the process to get it set up would be great!
James Williams
04-05-2008 14:02:34
 Re: Farmall F12 starter in reply to Steven f/AZ, 04-05-2008 08:37:33
Steve,I found a Bell housing and Flywheel,I made the part for the clutch cover{11/2 in spacer the same design as a 3 bolt starter}I cut the clutch cover out to fit the spacer.I used a starter off of a W6,Drilled the holes out so I could shift the starter up to alin with the flywheel.A lot of trial and error,It works perfect,Im sorry but I dont have a camera
jimmy
