Farmall 706 LP tractor
martin simmons
04-05-2008 07:56:51
third party image
How to get an Farmall 706 LP Tractor to start don't know anything about the tractor has been sitting in one of my fields for two years and the owner said i could have it it is propane powered so what are the steps to getting it started because i tried pulling the tractor but i cant get the Hydraulic lift up because this is the first tractor with Hydraulics i have ever owned and don't know how to work it so i need to get it started cause i could really use it to up my farming output and the tractor did run before the guy left it because it got stuck in a ditch and here are some pictures please help
thanks Martin
redstate
04-06-2008 06:29:25
 Re: Farmall 706 LP tractor in reply to martin simmons, 04-05-2008 07:56:51
Hey Martin, if there is no propane left in it, have your local propane delivery truck run out there when hes on his delivery route when hes close and fill er up. If you cant get a big truck out there, take your grill bottle, you will probably have to reduce with fittings off of the bottle to match with the tractor or like "a_lead" said hook up another tractor hyds. to the loader to raise it. I have used an old H, put a pto pump on the back and had enough power for a big loader, as long as the hyd resevior is with in the loader its self, or external from the tractor. You might leak out any moisture that may have collected in the rear end/hydrualic res. and crankcase oil before you try turnig it over because it will have seperated and goes to the lowest point, just losen the drain plug, let water drain until oil comes out. May or may not have any. put a little lube in the spark plug holes (something slick), cross your fingers and let her ripp. If you do get it started, give it a little time to get the hydrualics going for the tactor and the loader, dont be suprized if it doesnt want to steer, give it time to build up pressure and it should work. Ill take the hitch on the back for my 706 if its a lost cause but just a little tinkering and cleaning the cob webs and nests out you may have a nice tractor
martin simmons
04-06-2008 07:37:21
 Re: Farmall 706 LP tractor in reply to redstate, 04-06-2008 06:29:25
should i change the hydrualic fluid before i try to use it along with the oil and plugs etc.
Kelly C
04-06-2008 09:37:40
 Re: Farmall 706 LP tractor in reply to martin simmons, 04-06-2008 07:37:21
Yes if you get it started and plan on using the tractor. Replace all fluids and filters.
Now dont just change the fluid in the rear end unless your sure you are going to keep and use the tractor.
The capacity for the hydralics is 17 gal. That will run you about $160 or so plus the filter.
Order the manual. There is a place that sells all the IH manuals. I will email you the address. When I try to post it. The stystem stops it. I guess they are a competitor.
martin simmons
04-06-2008 11:57:50
 Re: Farmall 706 LP tractor in reply to Kelly C, 04-06-2008 09:37:40
here is my email could you send it to me texasryder12@yahoo.com
martin simmons
04-06-2008 12:02:18
 Re: Farmall 706 LP tractor in reply to martin simmons, 04-06-2008 11:57:50
also which levers do you use to operate the lift a pic will welp
redstate
04-06-2008 09:25:48
third party image
third party image
If was me, I would just leak out the moisture and if you get it going and back to your place and everything seems like its going to work, then go ahead and change everything (filters and oil). You would leak it out before you try anything just so it doesnt get mixed up again, and even if you dont get it started and pull it home, that moisture will still sort of mix. If you use the propane bottle to get it propane, here is an example how you might do it. The factory valve (liquid) losen the fitting, make sure the two valves are off, if my pitures came through, you can see on the bottle there is a series of fittings and a propane tube. hook the tube into the factory fittng on the tractor. You may need another fitting. I would think that you could get the fittings and tube for under $10. The bottle on my tractor is obviosly something added on but the same principle, the tube goes down to a regulator and then to the carb. I hope this might help, and be careful.
martin simmons
04-06-2008 11:50:27
 Re: Farmall 706 LP tractor in reply to redstate, 04-06-2008 09:25:48
third party image
before i start it i need two parts the double hose in the pic and the upper rad hose and could you show a pic of how to hook the small tank to the system main like a step by step because i still dont get what you mean but get the idea just need to see it done thanks
redstae
04-06-2008 18:40:31
 Re: Farmall 706 LP tractor in reply to martin simmons, 04-06-2008 11:50:27
and I forgot, some propane fittings are left hand thread
redstate
04-06-2008 18:33:28
third party image
third party image
Martin, all you are really doing is using the small tank instead of the tractors tank. the little diagram shows the fuel spply line(red) disconnected from the valve on the tractors tank(green) and then you have to match up fittings to connect the small tank(yellow) to the fuel line(red) that run straight down from the valve. I am assuming that the shut offs are as you look forward from the seat, thats the way it is on my 300LP. The double lines can prabably be replacated with some good hydrualic type lines and some good clamps, I believe those are low pressure return lines so you dont need the hyd. ends. Hope this helps and let us know
martin simmons
04-06-2008 20:00:29
 Re: Farmall 706 LP tractor in reply to redstate, 04-06-2008 18:33:28
Ok i get it (head slap) but i will have to see if the motor is not locked up first because all i had time to do today was replace the plugs, wires,and drain the water off the crankcase and once again thanks for all the help guys with all this advise it should be running by the end of this week so keep the help coming :)
martin simmons
04-06-2008 20:06:59
 Re: Farmall 706 LP tractor in reply to martin simmons, 04-06-2008 20:00:29
also how much run time do you get on a full tank will it be enough time to give the hydro. system time to build up enough pressure to raise the lift and steer the tractor and which levers control the lift
redstate
04-07-2008 08:22:51
 Re: Farmall 706 LP tractor in reply to martin simmons, 04-06-2008 20:06:59
your lift lever depends on how its hooked up. the tractor hydrualics is probably "on" to the hyd.circuit that powers the loader and there should be a seperated set of controls usually to your left as your sitting and in easy reach, for the loader, but you may just have to start moving controls untill you get movement.
redstate
04-07-2008 08:07:13
1 bottle will run an H (4 cylinder)for about 6 hours, it should get you home depending how far you need to go.
martin simmons
04-05-2008 19:34:34
any special lube's that any one know of that will help with that first start up like engine or Cooling System additives or that one special product that made your tractor get up and go because i will be going to the store later for plugs oil etc.
martin simmons
04-05-2008 18:23:56
Ok guys i need a parts manual any free offers on one LOL cause there are a few parts i need the upper radiator hose and a small hose that runs down the left side of the tractor(if you are in the drivers seat)there are two of them but i just need one or should i go on and replace both it looks to run somewhere up by the top of the radiator or somewhere on the left top in there if you look in the video you will see what i am talking about but i don't know what it is called and thank you for all the help
martin simmons
04-05-2008 15:49:02
thanks for all the help here is a quick video of the tractor as is stands now to give you a better idea of what we are dealing with no sound sorry
martin simmons
04-05-2008 15:52:28
 Re: Farmall 706 LP tractor in reply to martin simmons, 04-05-2008 15:49:02
a_lead
04-05-2008 14:30:42
If you can get another tractor close, disconnect the hydraulic hoses on the lift cylinders from the 706, and connect them to the other tractor. Use a pair off extension hoses (male/female) to reach the 2nd tractor if needed.
Use the hydraulic on the other tractor to raise the loader up. Then using 2 pieces of angle iron the same length, put 1 on each cylinder on the piston shaft so you can safety prop up the loader and release the pressure on the donor lift tractor. Use several hose clamps around the angle iron & piston to keep in place.
Then you can pull the 706 back to the house/shop/garage so it will be more convenient to work on, and if you drop something small it won"t get lost in the grass (don"t ask me how I know that).
Good luck. Edward
John A.
04-05-2008 14:18:05
Martin, This can be quite simple or complex But first start with some simple stuff. You have a gasoline engine with a different fuel delivery system,
1st... Check oil, loosen drain nut almost to the point of coming out, see if any water is in the crankcase. If no water retighten plug.
Check rearend oil for water, loosten plug like you did on the engine oil, let out any water, in none retighten plug
2nd...pull plugs, regap them, shoot a little oil in each cylinder, turn over engine with starter or a wrench on the front pully nut.
If stuck you will have to forumlate a new game plan,
If not replace plugs install new wires, check point-gaps
If you havent put batterys on Do so. also put new batt cables too the cable ends are bad just shut you eyes and do it.
If you can get a LP truck to give you a squirt of LP this tractor just might start Now.
If it doesn't they you could have a couple of three problems....Too much stuff to type....
Thunder Call Me and I will do my best to talk you through it. My # 512-577-3837!
Later,
John A.
El Toro
04-05-2008 11:26:13
Is there a way to connect a small bottle of LP similar to the one used on LP forklifts long enough to get it started to raise the loader and get it out of that field? You may need to unhook the loader for now so you can tow it out of there. Hal
Zach from TX
04-05-2008 10:51:30
I have a 706 almost identical. I started by putting a battery on it, turning the switch on and checking the distributor to make sure there is juice to it. I was lucky because there was still some gas in the tank. I turned the valve and made sure there were no big leaks. Then I had to short accross the starter to turn it over because the button had gone bad. I used a little ether to get it started. (It hadn't run in several years.) Then it took off and ran, have not had any trouble with it starting since. The hitch came up on mine when the engine cranked.
Silver Pig
04-05-2008 08:24:08
It doesn't look to be stuck in the picture, so I would think that they probably tore something up in the transmission or rear end when they pulled it out. Otherwise, he would have continued to use it.
El Toro
04-05-2008 08:10:15
You need to make sure you're getting fire to the sparkplugs. Rub the points with some 320 wet or dry until shiny. You will need a fully charged battery too. Is there propane still in the tank?
It should have an ignition switch like a tractor that runs on gasoline. Hal
martin simmons
04-05-2008 09:33:12
 Re: Farmall 706 LP tractor in reply to El Toro, 04-05-2008 08:10:15
he did not tear anything up he gave me the tractor because he got a bigger better tractor and i don't think that there is any propane in the tank but i don't know how to get it filled but i think if i get it filled and new plugs she will start right up but but the lift being down was the reason i could not pull it and i talked to another person that has a 706 and he said they will not pull in neutral but will pull in gear but getting the Hydraulics up is the problem
