No spark from mag
ScottyHOMEy
04-05-2008 15:32:13
'47 BN with an H4 mag, and I'm suddenly getting no spark. It was running just this past week.
When first started last spring after the engine rebuild, she fired and ran on the third pull of the crank, so the setup and timing have been good. She's run plenty since, though a few times she took a while to start (with the starter). I'd chalked that up to carburetion, but maybe not. Over the winter, the last few starts have been a matter of her firing maybe ten turns weakly, dying, and retarting only after some serious time on the starter.
I've had the mag off and back on twice today, after she wouldn't start at all. First time, changed out the condensor, touched up and checked the gap on the points. Second round, double checked the points, put yet another condensor in. I pulled the coil off to get a better look at the wire where it passes through to the points. It looks good and I had no continuity from the arm on the points to ground. I'm thinkin' it might relate to condenation (it livess in an unheated garage) as there was a film of rust I don't remember on the magnets, and on the rotor that becomes visible under the coil. Cleaned those up.
Still no spark to the center wire coming from the cover of the mag. The rotor in the cap is on.
Any thoughts? More things or ways to check it out?
El Toro
04-06-2008 04:03:03
 Re: No spark from mag in reply to ScottyHOMEy, 04-05-2008 15:32:13
third party image
You need to clean the points with a piece of 320 wet or dry until they're shiny. If they're pitted replace them and set the gap at .013".
An easy way to keep the mag in time is to note where the rotor is pointing before you pull the mag. It's best to make a little sketch, THEN DON'T MOVE THE ENGINE. To reinstall the mag just put the rotor in the postition shown in your sketch. The applies to a distributor too. Your coil may be ok and if the magnets are weak you won't have any spark or a very weak spark since the magnets are what creates the fire in a mag as they pass by the coil. You can check them for magnetism by touching them with a flatblade screwdriver. They should attract that screwdriver
with a lot of effort. Here's a mag off an old twin cylinder garden tractor with weak magnets.
Hal
gene bender
04-06-2008 02:33:48
You do have the rotor lined up with the cap when it fires dont ya. When ya put it bnack in ya did have it lined up to fire on TDC and not 180 deg off. When i get a mag serviced i fasten in a vice and with plug grounded turn it over with batt powered drill so i can check impulse and then at speed for fire before i install in engine.
ScottyHOMEy
04-06-2008 07:28:39
 Re: No spark from mag in reply to gene bender, 04-06-2008 02:33:48
I dunno, Gene. I left her sit last night since she was flooded. Went out this mornin' without doin' another thing to it, and she fired right off. She ran a little ragged at first, I figured the plugs were wet, and she straightened out and ran fine after about five minutes.
Could be weak spark, I suppose, but for the moment I'm gonna chalk this one up to dampness.
I don't know much about magnets, but I wouldn't think they'd go weak in a hurry, and I don't know if they work better when they warm up.
There was a lot of surfaace rust on the magnets from condensation that I cleaned up when I had her open last night. I'm thinkin' that might have cleaned itself up a little.
I left her run until she was warmed up, if only to get the battery charged back up after all the crankin' I did yesterday, and she was runnin' right when I shut her down a few minutes ago.
I'm gonna try runnin' it on a daily basis for the next week or so to see if it's gonna stay straightened out or if I'm gonna have to do somethin' else to get it right.
gene bender
04-06-2008 10:33:11
 Re: No spark from mag in reply to ScottyHOMEy, 04-06-2008 07:28:39
Ya must have it rite or it wouldnt even start. Probably needs to go for a ride for and hour or so. Just for kicks nex time you are going to shut it off just turn the gas off at the sediment bowl so it will run the carb dry. This will stop any flooding when sitting. Just remember to turn the gas back on when restarting.
Yugrotcart
04-05-2008 18:23:41
Scotty,
Here's a link to a mag manual.
Do you have the points set at .013?
Start on page 39.
Paul
ScottyHOMEy
04-05-2008 19:00:54
 Re: No spark from mag in reply to Yugrotcart, 04-05-2008 18:23:41
Hey, Paul.
If it's the one I'm thinking of, I've seen that and thought I had a link to it, but couldn't find it. Either I didn't grab it, or it saved as something I can't identify it among my (too) many bookmarks.
Your link posted as just text, though (no link). Can I ask you to give it another try?
Sure appreciate it!
Yugrotcart
04-06-2008 06:47:47
 Re: No spark from mag in reply to ScottyHOMEy, 04-05-2008 19:00:54
Mag manual.
Paul
Steven f/AZ
04-05-2008 16:26:53
If you have multi-meter, check the continuity (ohms resistance) through the coil... might be a bad coil?
Points and condensor are always first, and you have that covered. Are the magnets reasonably strong yet?
ScottyHOMEy
04-05-2008 16:53:55
 Re: No spark from mag in reply to Steven f/AZ, 04-05-2008 16:26:53
Both good ideas, as I can't really think of anything that's left in there. The impulse coupler is tripping fine. I figure a failure there would still make a spark, even if at the wrong time. There'd still be a spark at some point.
Any idea where the continuity should be on that coil? Across the two threaded ends or between one of those ends and the wire that runs to the head of the condensor?
I'm kickin' myself a little. I did think about the magnets both times I had it open. Not that I'd know a strong one from a weak one, but I thought and then forgot to see if they'd grab a nail I had on the bench and hold it.
Thanks!
Steven f/AZ
04-05-2008 19:53:46
 Re: No spark from mag in reply to ScottyHOMEy, 04-05-2008 16:53:55
ScottyHOMEy said: (quoted from post at 16:53:55 04/05/08)Any idea where the continuity should be on that coil? Across the two threaded ends or between one of those ends and the wire that runs to the head of the condensor?
Not sure where to test across or what the resistance should be - but if you try all possible combinations and get open circuits - then bad coil...
You could always give MagMan a shout - farmallmagneto.com
ScottyHOMEy
04-05-2008 20:30:32
 Re: No spark from mag in reply to Steven f/AZ, 04-05-2008 19:53:46
Thanks, Steve. I'd already put the project to rest for the day when I first posted because she's flooded to boot (of course!). The mag's on the tractor right now, and there's a few things that will be better/easier to check while its on.
But I'll put the analytical skills back to it tomorrow so that, with any luck, I can nail the problem down and get on the horn Monday to get what I need to get her fixed. MagMan'll be the first call.
I'm thinkin' while I'm at it, I need to eliminate a bad contact in the cover. Also gonna try checkin' for continuity to ground at the ground post (with the wire to the switch disconnected) while turnin' the engine by hand. Thinkin' that I should have continuity there when the points are closed, and lose it when the points open. If that's the case, I can eliminate a short in the wire from the points to the condensor. That'll pretty much leave the coil and magnet, or something affecting them.
Not sure that'll work 'cause the ends of the coil body are smack up against the magnets, so I'm not sure how or if it's isolated from ground, though it seems it would have to be. I'll just keep approachin' it as a learnin' experience.
Appreciate your help!
tinyy
04-05-2008 18:43:29
Is the switch to shut the tractor pulled out or set so it will run. Took me two days to figure out that the switch was not working right.
ScottyHOMEy
04-05-2008 18:56:30
 Re: No spark from mag in reply to tinyy, 04-05-2008 18:43:29
I knew a fella did that once. Closely related to my brother as I recall, think his name started with S. Left a rotor out once, but only once, too, this same guy.
Nope, I had the switch up and at one point, never even hooked up the ground wire back to the switch, figurin' I could touch it to and shut her down if everything went right.
Always worth askin', though, given my record. ;8^)
tinyy
04-05-2008 19:26:39
 Re: No spark from mag in reply to ScottyHOMEy, 04-05-2008 18:56:30
Are you grounding out on one of the wires in the mag(touching the housing)?
ScottyHOMEy
04-05-2008 20:32:58
 Re: No spark from mag in reply to tinyy, 04-05-2008 19:26:39
I looked for that but couldn't see anything. Gonna check that out with the multimeter in the morning. The wire from the coil to the condensor is obviously good, so it's the one to the points that will bear checkin' out.
