Re: farmall 140 oil pressures
Hugh MacKay
04-06-2008 12:12:48
kmm: I've got a 130, it's been doing that for 25 years and up until 4 years ago I used it enough to burn 500 IMP gallons of gas yearly. I still probably burn a 100 gallons. As gene quite normal.
You can make it better by work on oil pump, but as long as it's pumping oil I wouldn't bother. Even a few pounds pressure indicates it is pumping oil.
