Compression readings on Super M
NC Mike
04-06-2008 16:26:47
Took a set of compression readings on the sm today. The tractor was warmed up and all readings were at these pressures in 3 compression strokes. All held the readings with no loss of of pressure. #1 130 psi, #3 120 Psi, #4 130 psi, #2 128 psi. How would you rate these readings?
CNKS
04-06-2008 17:51:59
 Re: Compression readings on Super M in reply to NC Mike, 04-06-2008 16:26:47
# 3 is borderline, 117 would be down by 10%, (90% of 130) but if it was mine I would do nothing until it uses excessive oil. Powerwise you are fine. If it has step head or fire crater pistons, you are down some.
DCW
04-06-2008 16:34:41
Perfect.
