706 560 fenders
WHISKEY BENT
04-06-2008 16:45:39
ARE THE REAR FENDERS FOR THE EARLY 706/806 THE SAME ARE THE 460/560? THEY LOOK ALIKE BUT HAVE NEVER SEEN THE SIDE BY SIDE. THANKS!
CNKS
04-06-2008 17:39:37
 Re: 706 560 fenders in reply to WHISKEY BENT, 04-06-2008 16:45:39
Provided the 706 did not have the hex axle housing they will work without modification. Not familiar with the 706, I have heard that the later ones had the square housing. I have the fenders from the hex axle 706 on my 460, but I cut the hex part off and had a flat plate welded on. I have not seen them side by side either but I think all are the same except for the attaching points.
migraine
04-06-2008 17:36:23
Yes, they are the same fenders but the mounting brackets are different since the 560 has square axle and the 706 has hex. The pair on one of my 560 gassers came off a 806 and thus I had to change the mountings. Migraine
steveormary
04-06-2008 19:09:15
 Re: 706 560 fenders in reply to migraine, 04-06-2008 17:36:23
I took fenders off a 656 to put on a 706/ger.
I had to use spacers to get the fender to clear the tire.
steveormary
