C - Oil Pump removal
Steven F
04-06-2008 17:57:58
I remove the two bolts from the engine block and thought the oil pump would drop out. I tapped it lightly with a hammer and it still didn't come lose. What am I missing.
riverbend
04-06-2008 18:07:37
 Re: C - Oil Pump removal in reply to Steven F, 04-06-2008 17:57:58
The top part of the oil pump is a fairly good fit in the crankcase, it is the oil supply for the motor. Try turning the bottom of the pump from side to side while pulling down on it.
Greg
Greg 2010
04-06-2008 18:02:44
Turn the engine over slightly. The oil pump has gears that mesh sometime they are stuck. Basically if you have removed the two bolts it should come out. I just recently had mine out and had the same problem until I turne the engine.
the Unforgiven
04-06-2008 18:00:50
I just changed one about a week ago, two bolts in the block and it came out. Yours must just be stuck good.
