H radiator
Booth2563
04-07-2008 14:14:44
I got a new radiator for my H farmall. I need to know if there is some kind of pad that goes on the bottom or is there something I can make to put on the bottom before I put it on.
Thanks David
GordoSD
04-08-2008 08:14:07
 Re: H radiator in reply to Booth2563, 04-07-2008 14:14:44
Nylon reinforced rubber as in conveyor belts or balers. I have a lot of it around here. Buddy is in the belt business. Send me you address and I'll send you a piece big enough to make pads for the radiator AND the gas tank! Private email is open
Gordo
Booth2563
04-07-2008 15:15:50
Thanks guys That is what I thought but wanted to make sure. I cant afford to many $285.00 radiator.
Allan In NE
04-07-2008 14:56:38
Got any old flat belt lying around?
Cut a 2" diameter piece and poke a hole in the middle for the bolt.
Allan
Mike CA
04-07-2008 14:19:36
Yes there is a pad. Yes you can make them. I remember some people telling me material that they used to make them for themselves, but I don't recall the actual material. I bought them from OEM, but I may need to shave them down, as I think they are a little too tall. They aren't more than a couple bucks per pad. OEM, Stiener, and I'm sure a number of companies carry them.
